SEW-Eurodrive at the Hanover Fair
Sustainable drive solutions for the construction industry
Together with Knauf, SEW-Eurodrive will be showcasing drive technologies and solutions with which building material manufacturers can become fit for the future.
© SEW Eurodrive
Sustainable technologies and specific measures to conserve resources will be demonstrated at several stations along a gypsum production process, from extraction in the quarry to logistics in the outgoing goods department. These include reducing oil consumption in the gearbox by up to 30%, the use of digital twins, segmented gear rims that allow partial retrofitting and the use of intelligent condition monitoring to sustainably minimize downtimes. Other solutions that SEW-Eurodrive will be presenting are also fully focused on sustainability. The Eco2 version for geared motors, for example, allows resources to be conserved and costs to be saved. This is because the drives in an aluminum housing are available without any coating or painting for applications in closed rooms that are well protected from heat, cold or moisture. For these conditions, the energy-intensive coating and painting process can be completely omitted, especially as aluminum is not susceptible to corrosion. Another advantage is that, unlike painted gearbox housings, the uncoated components can be recycled more easily and in a more environmentally friendly manner at a later date.
Hall 6, Stand B26
SEW-Eurodrive
Starter set for aseptic area
Constantly changing consumer trends, smaller batches and sustainability demand more flexibility and modularity in the production process from the beverage industry. A starter set helps to adapt machines and systems to the market.
Mushroom
Safe handling of hydrogen
It is seen as an energy source of the future: hydrogen. There are risks involved in its production, handling and use that can be controlled with the help of safe automation technology.
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
