Dunkermotors
Peak power of 4.4 kW
With the BG 95x120 dPro, Dunkermotoren is expanding its product portfolio in the BG 95 series with a new length.
The motor from Dunkermotoren is currently the most powerful motor with a peak output of 4.4 kW and a torque of 14.5 Nm at a battery voltage of just 48 V(DC). Thanks to its space-saving slim design, it is ideal as a drive for mobile applications. Areas of application could include AGVs (Automated Guided Vehicles) or AMRs (Autonomous Mobile Robots).
It is connected via CANopen or the Ethernet interfaces Profinet, Ethercat or Ethernet/IP. The motor can be integrated into the existing system and then programmed and controlled via the "Drive Assistant 5" and/or "MotionCode". The certified STO function (Safe Torque Off) is available as standard. With STO, the motor can be switched off reliably and without torque.
