Siemens
Drive system for conveyor applications
Sinamics G115D is a compact drive system specially designed for horizontal conveying applications, comprising motor, frequency inverter and gearbox in a single unit and is available in two versions - wall-mounted or motor-mounted.
© Siemens
The drive system has a robust design and achieves protection class IP66. It operates in a wide temperature range from -30 to +55 °C and is suitable for applications in intralogistics and at airports as well as in the automotive and food & beverage industries. It is available in the power ranges 0.37 to 7.5 kW for wall mounting and 0.37 to 4 kW for motor mounting. According to Siemens, the drive system can be commissioned quickly with integration into the TIA portal, including the Startdrive commissioning software for setup and diagnostics or the 'Sinamics G120 Smart Access Module (SAM)' web server tool.
It is integrated into the entire 'MindConnect' portfolio and is compatible with 'Mindsphere' applications such as 'Analyze MyDrives'. Thanks to Profisafe, the drive has Safety Integrated in the form of STO (Safe Torque Off) SIL2. For flexibility in terms of installation, service and maintenance, the solution is equipped with a plug-in connector and flexible connection options.
Siemens
The tool-supported proof of safety
The relevant standards for functional safety in the process industry - IEC 61508 and IEC 61511 - are over 1000 pages long. For users, calculating and creating standard-compliant safety verifications is a challenge. Special tools offer assistance.
Siemens
The new products
This year's innovations from Siemens include the Sitrans MS Multisensor, which is used primarily for monitoring the condition of mechanical system components such as pumps, compressors, gearboxes and valves.
