KEB Automation at the SPS 2022
Yvonne Junginger,
Communicate securely via Profisafe
The Drive Controller Combivert F6 and Servo Drives S6 from KEB Automation offer integrated safety functions directly in the drive.
© KEB Automation
In the 'Application' device variant, Ethernet-based bus systems can be switched via software, enabling a flexible fieldbus connection to the higher-level control level, for example via Profinet. Communication via the safe Profisafe fieldbus protocol has now been integrated and certified in the devices. Drives with integrated safety are integrated into the Siemens TiA-Portal Profinet network using GSD files.
Based on this, safe fieldbus communication between different F-Devices (safety devices) is realized. With the KEB Drive Controllers Combivert F6 and S6 application (with safety module type 3), the corresponding encoder-related safety functions can be selected and used via the configuration. The device series cover a power range from 0.75 to 450 kW and can be used for the operation of different motor technologies.
SPS 2022: Hall 7, Stand 420
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
