Posital
Rotary encoder in 27 mm long housing
Posital has announced new models of the 'Ixarc' encoders with a housing length of just 27 mm. This reduced length combined with a diameter of 36 mm makes the devices particularly suitable for confined spaces.
© Posital
The radial cable entry and the shaft seal are designed in protection class IP65. A variety of flange and shaft configurations are available, reducing the need for adapters or special custom solutions. The encoders are based on Posital's magnetic measuring technology. Both incremental and absolute singleturn versions are available. Incremental versions are programmable: the resolution can be set via software from 1 to 16,384 pulses per revolution without having to change the mechanical properties of the devices. The pulse direction and the output driver - either push-pull (HTL) or RS422 (TTL) - can also be reset via software updates. Absolute versions have resolutions of up to 16 bits and are available with analog, CANopen or SSI interfaces.
Fraba
Two new divisions established
The internationally active Fraba Group has founded the new business units Credemus and Ubito. The two start-ups are positioning themselves in the 'Digital Transformation' and 'Wiegand Technology in the IIoT environment' business areas.
Posital at the SPS 2023
Encoders up to date
Posital has completed a comprehensive upgrade of its 'Ixarc' family of incremental encoders - and thus launched an overarching 'Nextgen' initiative. Jörg Paulus, European Managing Director, reports on the current status quo.
Fraba
Review of a successful 2022
The Fraba Group, supplier of industrial position sensors and Wiegand technology, can look back on a successful 2022. Highlights include the opening of a new production facility in Malaysia.
