Althen
Pressure measurement in hydrogen-based applications
There are three new pressure transducers from Althen that are suitable for hydrogen applications. The transducers named AGS4200H, HI2000H and HP1000H are based on the supplier's standard transducers of the same model, which have been adapted for hydrogen applications.
© Althen
Hydrogen is a particularly challenging medium for the wetted parts of an application. Due to its volatility and small molecular cell size, only certain metals can be used for the pressure connection, for example. If the molecular size of the hydrogen is smaller than the molecular lattice structure of the metal, the hydrogen diffuses through the metal and causes hydrogen embrittlement, which ultimately destroys the lattice structure of the metal. Certain steels such as high-alloy chromium-nickel steels or special metals such as Hastelloy C or Inconel, which are used at higher pressures, are suitable. All three new pressure transducers from Althen have been tested for their hydrogen compatibility and certified in accordance with ISO 1114-2:2017 as per EC79/2009.
The sensors differ in their respective areas of application: the AGS4200H is a basic version for standard requirements, which has an accuracy of 0.25 % and is designed for temperatures up to + 120 °C. The HI2000H corresponds to a higher specification. It has a higher accuracy of 0.1 % and is suitable for temperatures up to +200 °C within the application. HP1000H stands for High Pressure, a transducer that can withstand very high pressures of up to 5,000 bar.
Depending on the application, the pressure transducers are available with an analog or a digital RS485 interface.
Althen
Keeping an eye on the pressure
Theo is one of the three airships currently licensed in Germany. To ensure that its pilot has all the information about the pressure inside the airship, digital displays are installed in the cockpit to ensure that Theo flies safely.
Althen
Determined by DMS
In a material test, the properties and structures of a material are determined in the form of parameters using various physical or chemical tests and measurements. Reliable helpers in this process: strain gauges.
Althen
Danger of tipping over averted
Heavy transports with oversized loads require complex planning and logistics in order to be carried out properly and safely. Mobile measuring systems for monitoring the angle of inclination of the load ensure that the risk of tipping is minimized.
