Rotary encoder
Quelle: Baumer | Inka Krischke,
Mounting via Euro flange B10 and square flange
Baumer has expanded the Optopulse EIL580 encoder family and is introducing additional variants with the Euro flange B10 and square flange mounting types.
© Baumer
The incremental encoders in the series are based on a modular system that is constantly being expanded. The Euro flange B10 is a standard for mounting shaft encoders and meets the requirements for high reliability in applications such as rolling mills, the paper and wood processing industry and on cranes. The square flange designed in inch dimensions, on the other hand, is mainly used in US machines and systems. The versions with Euro flange B10 and square flange are based on optical scanning with finely graduated line numbers from 100 to 5000, developed for use in precision rotary encoders, and ensure accuracy and signal quality over a temperature range between -40 and +85 °C. In the programmable version, any line count from 1 to 65,536 and operating temperatures from -40 to +100 °C are possible. The permissible shaft load is 40 N axially and 80 N radially.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
Kübler at the SPS 2024
New generation of encoders
The 'Sendix' encoders have been an integral part of the Kübler product portfolio for many years. Now a new generation of encoders has been developed with state-of-the-art sensor and electronics technology that is suitable for integration into future...
