Megatron
More precise force measurements
The force sensors of the 'KT705' and 'KT805' series from Megatron have been equipped with analog electronics. This means that the force transducers also provide a negative output voltage or indicate when they are actuated in the opposite direction to the intended force.
© Megatron
The integrated analog amplifier eliminates the need for external electronics. According to Megatron, the sensors are compact and require less space and cabling in the application than sensors with a separate amplifier. The small diameter of the flexible cable (Ø 3.4 mm) also contributes to this. Another new feature is the individual test protocol that is included with each force sensor. Both force sensor series have the same options for the output signals (0 to 10 V / 10 to +10 V / 4 to 20 mA) and the same electronics, but differ in terms of nominal forces, size and material. While the measuring body and housing of the 'KT805' are made of nickel-plated steel, the 'KT705' is made of aluminum. Both force sensors work according to the Wheatstone strain gauge full bridge principle. The 'KT705' measures nominal forces of 200 N, 500 N and 1 kN, while the 'KT805' can measure forces of up to 2 kN and 5 kN.
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
Megatron
Angle measurement in the smallest space
Thanks to their housing depth of just 6 mm and a housing diameter of 16.4 mm, the hollow-shaft conductive plastic potentiometers in the 'MHP16' series from Megatron are particularly suitable as position indicators in motor valves and actuators.
Joysticks
Protected against dust and splash water
The Hall-effect finger joystick of the 847 series from Megatron is manufactured in protection class IP67 and is therefore protected against dust and splash water. Its soft-touch feel enables easy and precise control of work machines in harsh...
