Balluff
Inka Krischke | Tiffany Dinges,
High-temperature sensors with approval up to 135 °C
The current generation of BES inductive miniature sensors from Balluff in the M05 housing now also offers tolerance to high temperatures in addition to functional reliability and small size.
© Balluff
According to the manufacturer, these are the only inductive sensors in this design on the market with a permissible operating temperature of up to +135 °C. As the electronics are fully integrated into the housing, the sensors do not require external amplifiers and, with their small dimensions of (Ø 5 mm x 27 mm or Ø 5 mm x 42 mm), can also be fitted into particularly tight installation spaces. The sensors are particularly suitable for use in semiconductors and hydraulics, as they are approved for dynamic pressures of up to 10 bar and static pressures of up to 100 bar. The oil and temperature-resistant silicone cable is connected to the housing with a special crimp, which guarantees IP67 protection.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Balluff
Read out data via IO-Link
Reliable and wear-free monitoring of the clamping process plays a central role in tool spindles and tool changers of a machining center. Balluff offers the BIP01 inductive position measuring system for this task.
Balluff for SPS Connect
Simply retrofitted
Last year, Balluff introduced the 'BCM' condition monitoring sensor, which records four measured variables with just one device. Stefan Hornung, Portfolio Manager for Condition Monitoring Solutions at Balluff, explains what has happened since then...
Balluff
Connect drive technology directly
Balluff offers special Ethernet/IP network modules for assembly and conveyor technology. The IO-Link masters BNI00EF and BNI00EH enable the fast integration of different IO-Link devices into existing networks.
Balluff
Smart sensor technology for the IIoT
In addition to status information, intelligent sensors provide a wealth of secondary data - on service life, load level and damage detection as well as ambient temperature or contamination. Optical sensors in particular are undergoing a lot of...
