Rutronik
For a switchless look
The Capacitive Hidden Switch (CHS) from Schurter works without mounting holes in the user interface and can therefore be installed inconspicuously.
© Rutronik
The sensor from Schurter (available from Rutronik) is particularly suitable for devices with high hygiene standards, such as in the medical or food industry. It also opens up new possibilities in the design of user interfaces. The capacitive switch triggers without direct sensor contact with the finger. It uses an electrical field on the user surface of the sensor. As soon as a change occurs there, the sensor reacts. It is also possible to use non-conductive materials such as glass, plastic or wood between the sensor and the surface. The sensor is attached behind the surface using transfer adhesive tape. This means that no drill holes or slots are required. There are also no moving parts. Bacteria, viruses or fungi can therefore hardly settle on the user surface.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
