BD|Sensors
Flexibly configurable pressure switch
With the electronic pressure switch series 'DS35x' from BD|Sensors, users can configure the devices to suit their individual requirements thanks to a wide range of setting options.
All variants have an IO-Link interface, which simplifies access to device status, parameter configuration or signal quality. A multiple continuously rotatable display, which visualizes the recorded measured values on a four-digit LED display, ensures good readability in practical use. The signal output of the devices can be switched between the variants IO-Link, PNP, NPN as well as current 4 to 20 mA and voltage 0 to 10 V.
The pressure switches from BD|Sensors are available in three versions: In the standard variant 'DS 350', the switch has a stainless steel sensor combined with industrial-grade connections, also made of stainless steel. The 'DS 351' version with a robust ceramic sensor is suitable for demanding measurements in aggressive media. In the 'DS 350P' version, the pressure switch is available with various process connections and is aimed at hygienic applications.
