Sensor network
Quelle: Harting | Inka Krischke,
Communication via radio
Harting offers the edge computing system 'Mica (Modular Industrial Computing Architecture)' to know the status of machines and process data further.
© Harting
Together with Arrow Electronics, the Mica Wireless Sensor Networks were developed to integrate wireless sensors. Arrow Electronics developed a function module that communicates with sensors via various wireless protocols. Via SmartMesh IP (Dust)/ Bluetooth Low Energy and an XBee slot, it is possible to wirelessly record and process sensor data via "Mica" independently of the existing machine control system. These protocols were chosen to give suppliers of wireless sensor technology various options for connecting their sensors to "Mica" directly or via sensor nodes. The combination of wireless sensors and the edge computing system makes it possible to monitor old existing systems (condition monitoring). Operating times, temperatures and various environmental parameters can be determined and monitored without the cost of cables, networks and expensive industrial sensors.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
