Vega
Inka Krischke | Tiffany Dinges,
3D system planning right from the start
A virtual journey can help to efficiently define the appropriate level, interface and pressure solutions for refining and petrochemicals in a refinery in advance. Vega demonstrates this using a 3D animation.
© Vega
Refineries have numerous complex production processes for processing crude oil into higher-value products. There are often many hundreds of meters and stations such as columns, depropanizers, flare systems and retention or condensate tanks between the individual process steps. Many process steps - distillation, cracking, desulphurization, filtration or storage - must interlock seamlessly.
What this looks like in detail can be seen on a tour with the 3D animation from Vega. With just a few mouse clicks, visitors can dive deep into the respective plant areas and see the use of the appropriate measurement technology in detail.
The video offers a brief insight into the extensive application areas of the digital tour.
You can experience the complete tour with all applications, areas of use and process stages here.
Jumo
Horizontal version
The Nesos R40 LSH from Jumo is a new member of the Nesos series, which includes devices for point level measurement using a float and reed contact and for level measurement using a float and reed chain.
Nivus
Flowmeter with IoT function
Nivus offers the 'Nivuflow' devices with a mobile radio modem with worldwide approval. The manufacturer's IoT concept allows the operator automatic data transmission in conjunction with many visualization and logging options.
TDE Instruments
Modbus interface included
The Digalox series of measuring devices from TDE Instruments is now also available with a Modbus interface. According to the manufacturer, the graphical multifunction measuring devices with RGB backlighting offer extensive functions and display...
Vega
No need for cabling
Vega is launching the self-sufficient 'Vegapuls Air' radar sensors on the market in early 2021. Product Manager Clemens Hengstler explains what makes them so special.
Vega
Sensor portfolio completed
With the Vegabar pressure sensors and Vegapoint point level switches, Vega has become a full-range supplier for level and pressure in food and pharmaceutical processes.
