Voltage monitor
Quelle: Pilz | Inka Krischke,
Variable application range
With the PNOZ s60 voltage monitor, Pilz offers monitoring for the voltage-free status of plant and machinery in accordance with the UL6420 standard.
© Mushroom
This makes it suitable for applications that require a Safety Lockout System (SLS), i.e. the maintenance of systems in a safely de-energized state. The PNOZ s60 complements the PNOZsigma safety relay product group and meets the requirements for implementing SLS applications, which are required by law in the USA. It monitors de-energized 1-phase or 3-phase networks with a neutral conductor. Two switching thresholds can be set: 12 V or the usual 6 V in the food and beverage sector. The safety circuit is only enabled when the voltage falls below the configured switching threshold. With a supply voltage of 24 to 48/110 to 240 V(AC/DC), the device can be used flexibly in a wide range of applications. LEDs enable the user to carry out simple diagnostics and assist with troubleshooting. The width of 90 mm allows space-saving installation in the control cabinet.
Safety
News from safety-related automation
With increasing cycle rates, machine functions are becoming ever more complex - against this background, the topic of functional safety is becoming increasingly important. Computer&AUTOMATION shows a selection of current products relating to...
Linear drive
Buffer zone shortened
If you are dimensioning a travel drive or a linear drive, you need to install a mechanical buffer at the end of the travel path to be on the safe side. LTI Motion offers the solution here.
Safety
With increasing cycle times, machine functions are becoming more and more complex - against this background, the topic of functional safety is becoming increasingly important. Computer&AUTOMATION shows a selection of current products relating to...
Pilz
India sets safety standards
India, the world's fastest-growing economy, is establishing a legal framework for machine safety - with implications for machine manufacturers and exporters, some of which will take effect as early as November 2025.
