Warning from the VDE
Davina Spohn,
Security risk with old fax machines
Due to its connection to the company network, the fax machine has become a security risk in companies: According to the VDE, telephone lines serve as a gateway for hackers. Unlike data lines, they are not protected by special security mechanisms.
Old fax security vulnerability?
© Fotolia, Joachim B. Albers
If a hacker sends faxes with malicious code - disguised as an image file, for example - to a fax machine or an all-in-one printer with a fax function, the code causes the machine to "lose its rhythm": A memory overflow is provoked. This allows the attached malware to be executed and gives criminals unhindered access to the entire network. "Faxes are still often sent, especially in the healthcare sector and in public authorities. Many all-in-one printers also have a fax function," says Alexander Matheus, SenioR Expert in the field of smart technologies at VDE. The tricky thing about the attacks is that the "receipt" of the malicious fax is not necessarily recognizable on the device - "Even warning tones are not emitted," says Matheus. This type of attack is applicable to many fax machines, as the telephone lines, unlike the other data lines, are not protected or monitored by special protective mechanisms.
Recommendation of the VDE
The VDE Institute recommends deactivating fax machines that are not in use or the fax function on all-in-one devices. All you have to do is disconnect the telephone connection. If it is not possible to disconnect the fax machine from the rest of the network, users should definitely wait for updates from the manufacturer and then install them quickly. "The example of fax machines clearly shows that companies, organizations and authorities, but also consumers, must constantly consider and evaluate all possible communication channels. Companies and authorities must draw up a security concept that they must regularly review and revise, as the attack scenarios are constantly changing. Outdated devices and communication protocols used must also be constantly evaluated to see whether they still meet the requirements," explains Matheus.
Security
No accidental changes to files
CodeMeter 6.80 from Wibu-Systems supports Universal Write Filter (UWF), a Windows option from Microsoft that prevents accidental changes to files, which is particularly important for embedded systems.
