Pilz at the SPS 2021
Safe motion monitoring functions in accordance with EN 61800-5-2
The safety card PMCprotego S3 extends the drive-integrated safe motion solution 'PMCprotego DS' from Pilz with additional safe motion monitoring functions to EN 61800-5-2.
© Mushroom
With these functions, an application-specific error response can be configured in advance using the 'PASmotion' engineering tool. The safe motion monitoring functions include the safely monitored direction of movement (SDI-M), the safely monitored increment (SLI-M), the safely monitored speed (SLS-M) as well as the safely monitored operational stop (SOS-M), the safely monitored position (SLP-M) and the safely monitored speed range (SSR-M).
Communication takes place via the real-time Ethernet Safetynet p RTFL, which enables safe cross-communication between all drives equipped with a safety card in the application. The drive-integrated solution can also be connected directly to the small controller 'PNOZmulti 2' via Safetynet p. It is also open to common motor types and feedback systems and supports standard communication via Ethercat and Profinet.
Pilz at the SPS 2021: Hall 9, Stand 370
Mushroom
Monitor axles safely
The motion monitoring module PNOZ m EF 1MM2DO of the configurable small controller 'PNOZmulti 2' from Pilz also offers the functions cascading and delayed switch-off in the area of safe motion monitoring.
Mushroom
Extensions in the software tool
In the software tool PNOZmulti Configurator of the configurable small controller 'PNOZmulti 2' from Pilz, new function blocks are available from software version 10.13 for easy configuration of safe user programs.
QNAP Systems
Next-Generation Switches
QNAP has announced the new generation of its QSW-M2130 L2 Web-Managed Switch series. It is available in two models—the standard model “QSW-M2130-4C2S24T” and the PoE++-capable model “QSW-M2130P-2C2S26T.”
