Indu-Sol at the SPS 2025
Network status made transparent
With 'Promesh P24+', Indu-Sol offers a Gigabit Ethernet switch with 24 ports that is designed for both Profinet and Ethernet/IP.
© Indu-Sol
In addition to the high port speed, the diagnostic switch has four uplink ports that support up to 10 Gbps. This means that large amounts of data can be bundled and forwarded to higher-level systems without the switch itself becoming a bottleneck. The switch is particularly suitable for applications in the backbone. It offers comprehensive environmental and port monitoring by permanently monitoring the quality of all connected cables, measuring the leakage current and recording environmental factors such as vibration, light or humidity at the installation site and displaying them graphically in the web interface. Detailed port statistics such as errors, discards, network load (per ms or s) and information on the network topology and neighborhood can also be visualized and user-defined triggers can be set to generate and display corresponding alarms. The switch can be individually connected to the machine and production network using NAT.
Hall 5 Stand 260
Weidmüller
Dr. Sebastian Durst becomes CEO
The Weidmüller Group is strengthening its first management level as of October 1, 2024: Dr. Sebastian Durst, previously Chief Operations Officer, will take over the newly created position of Chief Executive Officer (CEO).
HMS Networks
Cybersecurity for industrial networks
With 'Anybus Defender', HMS Networks presents a new product range for the highest cyber security requirements in industrial environments. The new product range offers protection for networks in the manufacturing industry and for the critical...
Most read
The top articles in July 2024
Innovative spirit and entrepreneurial thinking characterize the most-read articles from July. Find out more about competitive advantages through AI, click through award-winning developments and read more about model-based design and quantum sensor...
