Light curtains
Protective field heights from 150 to 1200 mm
Datalogic announces the launch of the new range of Slim Safety Light Curtains, a guarding solution for a wide range of automatic and semi-automatic machines.
To protect their operators, systems for assembly, packaging, filling, sorting, inspection, measurement, material handling and many other applications require safety light curtains. According to the manufacturer, the safety light curtains are designed so that they can be integrated into existing machine structures, especially when a space-saving solution with small distances to the danger zone and frequent operator intervention is required. The series offers three resolutions: 14, 24 and 34 mm are available. Various mounting options are designed to simplify fitting into installations. All models can be cascaded up to three units. 34 protective field heights from 150 to 1200 mm are intended to offer a comprehensive selection.
