Light curtains
Quelle: Datalogic Automation | Lukas Dehling,
Protective field heights from 150 to 1200 mm
Datalogic announces the launch of the new range of Slim Safety Light Curtains, a guarding solution for a wide range of automatic and semi-automatic machines.
© Datalogic Automation
To protect their operators, systems for assembly, packaging, filling, sorting, inspection, measurement, material handling and many other applications require safety light curtains. According to the manufacturer, the safety light curtains are designed so that they can be integrated into existing machine structures, especially when a space-saving solution with small distances to the danger zone and frequent operator intervention is required. The series offers three resolutions: 14, 24 and 34 mm are available. Various mounting options are designed to simplify fitting into installations. All models can be cascaded up to three units. 34 protective field heights from 150 to 1200 mm are intended to offer a comprehensive selection.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
