Muting controller
Quelle: Leuze Electronic | Inka Krischke,
Individually selectable time-out times
With the MSI-MD-FB, Leuze presents a controller for the external control of muting processes. It is mounted directly on the machine and only requires one cable to the control cabinet.
© Leuze Electronic
The external control unit supports the multiple light beam safety devices 'MLD' and the safety light curtains 'MLC'. Three modes - 2-sensor parallel, 2-sensor sequential and 4-sensor sequential - are available. An optional muting enable signal can be used for additional protection against tampering. Selectable time-out times from 20 s to 100 h make it easier to adapt the muting processes to the application. Configuration is via DIP switches. An additional micro-USB diagnostic interface enables access to diagnostic data at any time. The IP67 plastic housing allows installation in the manufacturer's 'UDC/DC' device columns. The temperature resistance of -30 to +60 °C also supports use in deep-freeze areas.
