Sigmatek
Function modules for safe workspace monitoring
The 'Lasal SafetyDesigner' engineering tool from Sigmetek includes two new safety function blocks for workspace monitoring of serial kinematics, 'Denavit-Hartenberg (DH) Transformation' and 'Collision Detection'.
© Sigmatek
The 'DH transformation' module converts spatial input coordinates into spatial output coordinates. A multi-axis robot arm can be realized by using the module multiple times. The resulting coordinate system defines the TCP (Tool Center Point) of the robot. According to Sigmatek, 'Collision Detection' prevents a collision between the TCP of a robot and other objects in its working environment. The minimum and maximum XYZ coordinates define the workspace. They span a cuboid that is parallel to the coordinate system. This workspace is the area in which the TCP is allowed to move. In addition, an enveloping sphere is placed over the current position of the robot. Collision detection detects collisions by comparing the enveloping sphere with the defined workspace limits.
Sigmatek
Object-oriented into the future
Sigmatek presented the LASAL software platform with object-oriented programming (OOP) in 2002. The company was the first automation solution provider to move away from strictly sequential programming and has been using object-oriented programming...
Friedhelm Loh Group
Managing Board expanded
The Friedhelm Loh Group is aligning its group of companies for the future and is expanding its Executive Board to include Prof. Dr. Niko Mohr. He joins owner and CEO Prof. Dr. Friedhelm Loh and CFO Ralph Lindackers on the Executive Board.
