Safety
Quelle: Sigmatek | Inka Krischke,
Connect safety elements decentrally
With the SIB 061 Safety Input Box from Sigmatek, safety-related elements can be connected directly to the machine or system.
© Sigmatek
Equipped with six digital safety inputs (3 mA/24 V(DC)/0.5 ms), the signals from a maximum of three control and signaling devices (2-channel) can be read in decentrally. Combined with a safety controller from the supplier, the 'Safety Input Box' is designed to meet the highest safety requirements and is TÜV-certified (SIL 3/PL e, Cat. 4). The box is mounted directly on the machine, on a control panel or on the back of the 'ETT' multi-touch control panels. Input signals from safety elements such as emergency stop, enabling switches, operating mode selector switches and key switches can thus be collected decentrally and transmitted safely to the 'S-Dias' safety CPU in the control cabinet using a 2-wire cable. Communication between the 'Safety input Box' and the safety CPU takes place via a safety-oriented 2-wire bus according to the black channel principle. Status LEDs directly next to each channel ensure clear assignment. The safety-related application can be programmed and configured using the 'Lasal Safety Designer'.
Safety
News from safety-related automation
With increasing cycle rates, machine functions are becoming ever more complex - against this background, the topic of functional safety is becoming increasingly important. Computer&AUTOMATION shows a selection of current products relating to...
Linear drive
Buffer zone shortened
If you are dimensioning a travel drive or a linear drive, you need to install a mechanical buffer at the end of the travel path to be on the safe side. LTI Motion offers the solution here.
Safety
With increasing cycle times, machine functions are becoming more and more complex - against this background, the topic of functional safety is becoming increasingly important. Computer&AUTOMATION shows a selection of current products relating to...
Codesys
Virtualized Control Technology in Practice
Software determines functionality in televisions, vehicles, smartphones, and increasingly in industrial automation and industrial control systems. This development has led to the emergence of virtual PLCs (vPLCs). The following article describes how...
