Linear drive
Quelle: LTI Motion | Inka Krischke,
Buffer zone shortened
If you are dimensioning a travel drive or a linear drive, you need to install a mechanical buffer at the end of the travel path to be on the safe side. LTI Motion offers the solution here.
© LTI Motion
If you are dimensioning a travel drive or a linear drive, you need to install a mechanical buffer at the end of the travel path to be on the safe side. LTI Motion offers the solution here. In the relevant standard for storage and retrieval machines, for example, the speed to be taken into account for the buffer design may be reduced to 70 % for the calculation if safety functions in accordance with DIN EN 528 are used. As the speed is included in the calculation of the buffer zone in quadratic form, this safety function reduces the length of the buffer zone to less than half. This principle can also be applied to travel drives and linear axes outside of storage and retrieval machines. Among other things, the company offers the necessary safety functions such as SLS (Safe Limited Speed) or SCA (Safe CAM = safe cam) integrated in the ServoOne servo drive system or in the SystemOne CM automation system. This means that the buffer zone can also be shortened here with safe monitoring of the travel drive. This gives the machine more space for the active working path: it becomes smaller or faster.
Safety
News from safety-related automation
With increasing cycle rates, machine functions are becoming ever more complex - against this background, the topic of functional safety is becoming increasingly important. Computer&AUTOMATION shows a selection of current products relating to...
Safety
With increasing cycle times, machine functions are becoming more and more complex - against this background, the topic of functional safety is becoming increasingly important. Computer&AUTOMATION shows a selection of current products relating to...
Codesys
Virtualized Control Technology in Practice
Software determines functionality in televisions, vehicles, smartphones, and increasingly in industrial automation and industrial control systems. This development has led to the emergence of virtual PLCs (vPLCs). The following article describes how...
