KHT
Warehouse robot picks over 500 items per hour
KHT has redesigned the function and design of the Indu-Store picking system. The warehouse robot processes each item automatically via integrated Auto-ID solutions.
© KHT
Using various storage options, the goods are fed to the picking system, where they are picked up by a robot and automatically assigned to the optimum shelf location. The gripper of the 'Indu-Store' does not move to predefined storage locations, but continuously reallocates the areas dynamically.
According to the supplier, picking rates of more than 500 items per hour are achieved using multi-pick and combi-pick strategies. All processes are seamlessly monitored by sensors and the associated software. The system can be operated and monitored remotely.
Yaskawa
More power for the Cobot
With the Motoman HC20DT IP67, Yaskawa is expanding its current range of collaborative robots with a significantly larger model that is designed for a higher payload and an extended working range.
Schaeffler
Drive technology for robotics
Robots and cobots have to meet high requirements. This also applies to the components used in the articulated arm bearings or as range extenders. New bearings, precision gears and linear axis systems meet these requirements.
Fruitcore
A robot called Horst
The aim when developing Horst was to create a robot solution that is simple both mechanically and in terms of software and that is specially tailored to the needs of small and medium-sized companies. What is behind this?
Visam
Interfaces for more reports
With VBase 11.6, industrial IT provider Visam offers an updated version of its automation platform for HMI, SCADA and MES applications. With the new RDLC interface, recorded data can be output to the screen or printer in the desired format.
