Collaborative robots
Quelle: Omron | Inka Krischke,
Twelve models available
Omron launches collaborative robots of the TM series on the market. The company is also launching a mobile-compatible model that can be seamlessly combined with the mobile robots from the 'LD' series.
© Omron
This enables manufacturers to automate complex processes such as pick-and-place on transport containers and flexibly connect their production processes with the help of mobile robots. The robots in the 'TM' series are available in twelve models with arm lengths of 900, 1100 and 1300 mm for payloads of 4, 6, 12 and 14 kg. There are models that comply with the SEMI S2 safety guidelines as well as models that do not. Thanks to the flowchart-based, intuitive interface and simple teach functions, little to no prior knowledge is required to program the robots. The robots have an integrated vision and lighting system that captures products from a wide viewing angle. Thanks to many core functions such as pattern recognition, barcode detection and color recognition, inspection, measuring and sorting applications can be easily implemented.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
