Transportation systems
Quelle: Kuka Systems | Inka Krischke,
Skids interchangeable in time
The KS Pulse (Propulsion Using Linear Synchronous Energy) is a pallet-based transport system from Kuka Systems that moves the various body parts in an automated assembly line quickly and safely through the individual workstations of a system.
© Kuka Systems
The main element of the transport system is a carrier. This transports the individual body components through the assembly line with the help of different transport carriages - so-called skids. The carriers are moved through the system's process stations by linear synchronous motors. Thanks to the use of very few moving parts, the system has a low susceptibility to faults. The skids are interchangeable in the cycle so that several models can be run on one line. In addition, components such as turntables or buffer stations can be integrated into the system in order to adapt the system to individual production scenarios. The carriers, i.e. the approach to the individual stations, and collision protection are controlled by software. No additional sensors are required for precise positioning to ±0.1 mm.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
