Fraunhofer IPA
Robots learn to assemble thanks to AI
Flexible robot programming for assembly tasks is still complex. The aim of the 'Rob-akademi' research project is to improve this.
The 'Rob-akademi' research project aims to significantly simplify robot programming for assembly tasks.
© Fraunhofer IPA / Rainer Bez
The partners in the 'Rob-akademi' research project, including the Fraunhofer IPA and the Institute of Industrial Manufacturing and Factory Operation IFF at the University of Stuttgart, are developing technologies that will simplify and automate robot programming for assembly tasks. The basis for this is a purely digital image of the production environment, a digital twin. This image, combined with a special programming framework, is used in a physical simulation environment so that robots learn skills for flexible assembly. They autonomously explore their environment in the simulation environment, plan their behaviour based on this and optimize it independently or learn continuously. Artificial intelligence (AI) is used for this - more precisely, machine learning and its sub-area of reinforcement learning (RL). This means that an algorithm learns according to the principle of trial and error, similar to humans. The algorithm receives a reward signal for a successful action in order to gradually improve.
The project is creating three application-related learning modules that encapsulate expert knowledge about robot programming and the assembly operation to be carried out: The 'Perception module' for object recognition, the 'Force-controlled joining' learning module for robust joining strategies and the 'Snap-fit connections' learning module with a detailed physical joining model. These technologies are used to create robust robot programs for transferring the simulation results to reality. The project partners are validating their results with the help of three practical use cases - control cabinet, switch and PCB assembly. The modules for force-controlled joining and snap-fit connections are based on the already available IPA software 'pitasc' for force-controlled assembly tasks and will expand its capabilities.
With its project objectives, 'Rob-akademi' addresses the needs of increasingly personalized production in particular. Assembly applications currently still place high demands on robot programming. These include diverse and simultaneously demanding, often force-controlled processes, a high number of variants and short cycle times. For many companies, and especially SMEs with their customer-specific products, it is therefore often not yet worthwhile using robots for assembly, especially as only an expert can carry out the programming. Robots offer advantages such as taking over non-ergonomic, dangerous or monotonous tasks and consistent quality in the execution of tasks.
The project is part of the major funding measure 'KI01 KI in der Praxis' of the Federal Ministry of Education and Research. Another Fraunhofer IPA research project is part of the same funding measure: 'Deep Picking' uses AI to optimize robot-based picking. The IFF is involved in the 'AI-based robot calibration' (KIRK) project.
Smart production
The smart Robot Factory
Connecting a production cell to the cloud during ongoing production and providing it with all the features of a smart factory: Kuka has now realized this goal with partners from the Open Industry 4.0 Alliance.
Fraunhofer IPA
Low code for service robots
Launched in 2017, the SeRoNet project aims to significantly simplify the design, development and use of service robots. With 'xito.one', an open IT platform is currently being created for users, solution providers, robotics and component...
drag and bot
Programming via drag & drop
A weighty argument that is often put forward against the purchase of an industrial robot - in addition to the price - is the effort required for programming. But what if this could be done via software as easily as setting up a smartphone?
Weidmüller
Democratization of machine learning
The 'Industrial AutoML' software enables companies to implement machine learning models independently - without a data scientist. The application engineer contributes their domain knowledge and the software automatically creates the ML model.
