Wandelbots
Programming even by non-professionals
The TracePen from Wandelbots makes it possible to assign tasks to robots easily and without programming knowledge. According to the provider, even non-experts can use it to train robots for a task.
© Wandelbots
To do this, the operator uses the wireless 'TracePen' in their hand to simply show the robot the path to be learned directly on the workpiece. This movement is visualized almost simultaneously by the Wandelbots software in the app belonging to the product. The user can then refine the path intuitively and in the sub-millimeter range on the iPad. It is possible to define whether the robot should move from point to point, linearly or in a circle between the defined points, depending on the application. An integrated joint control system allows the user to directly influence the individual robot joints. It is also possible to define a specific safety zone in which the robot is allowed to operate.
If the path meets the requirements for the process step, the operator of the
operator of the app transfers it to the robot. The Wandelbots software translates the path into the respective robot-specific programming language.
The learned process step can easily be transferred to other robots from other manufacturers.
IFR
Germany in 1st place for robots in Europe
With around 221,500 industrial robots, Germany is the most automated economy in the EU - the number increased by 3% (2019). This was reported by the International Federation of Robotics (IFR) with the publication of the World Robotics 2020 yearbook.
Universal Robots
Seeing cobots
Small and medium-sized companies are also successfully opening the door to the future with the help of collaborative robots or cobots. One of the key foundations for this is the seamless interaction between robots and image processing.
