Drive technology
Andreas Seegen, Marco Antoni | Günter Herkommer,
Micromotors in use with diving robots
Deep-sea diving robots have to function reliably up to 10,000 meters below sea level and withstand enormous pressures - a particular challenge for the drive technology used, among other things.
© Ronnie N. Glud
The search for alien life is often associated with distant planets. However, there are areas right on our doorstep about whose inhabitants we know less than about the surface of Mars. For example, the biological and chemical processes that take place in deep-sea trenches are still largely unknown. The 'Hades-ERC' research project therefore aims to provide new insights into these oceanic abysses.
The so-called hadal zone begins 6000 m below the water surface and extends to the sea floor. Its deepest point is in the western Pacific in the Mariana Trench, around 11 km below sea level. The ambient pressure, which increases by one bar for every 10 m of depth under water, is accordingly 600 to around 1070 bar at the deepest point.
Figure 1: The Hades ERC robot takes samples of the bottom sediment and brings them to the surface for analysis.
© Ronnie N. Glud
"There is a simple basic rule in marine biology," says Professor Ronnie Glud from the University of Southern Denmark in Odense. "The deeper you go down, the fewer creatures you encounter". This is because not only does the pressure increase with increasing water depth, there is also less and less sunlight and food sinking down from above, such as phytoplankton. Therefore, little biological activity is actually to be expected in the hadal zone, depending on the depth.
However, gravity acts everywhere and sooner or later some of the biomass produced at the surface inevitably sinks further and further towards the ocean floor. This mass, also known as marine snow, collects there and serves as food. Biological activity therefore breaks with the trend and rises again, as Professor Glud discovered in 2013. "We found more organic turnover below 10,000 meters than at 6000 meters," he sums up. He therefore assumes that the trenches have a disproportionately large influence on the nitrogen and carbon balance of the oceans. Although they only make up around 2% of the ocean surface, they could therefore have a disproportionately large effect on theCO2 balance and climatic events.
In order to answer the question of the influence of ocean trenches on the Earth's climate, his faculty in Odense, together with marine biologists from the University of Copenhagen and marine science institutes from Germany, Japan and Scotland, is investigating the hadal microbes in the Hades-ERC project. The researchers are facing two major difficulties:
Figure 2: The DC micromotors used in the submersible robot passed the practical tests for use in the extreme conditions of the hadal zone without any problems.
© Faulhaber
Manned dives to depths of several kilometers are possible in principle and have already been carried out, but they are complex, expensive and dangerous. Instead, an autonomous robot is used to take samples of the bottom sediment and bring them to the surface for examination. However, without further precautions, the collected microbes, which are adapted to the high pressure, would burst during the ascent due to the drop in pressure, making the sediment samples worthless.
The robot itself must also function reliably in every pressure range from the surface to the seabed so that it can successfully descend, collect the samples under pressure, preserve them with fixative and finally rise back to the surface together with the samples. The drive, the sensors and the tools that touch the sediment also have to perform various movements during this process and work autonomously under water for many hours.
After a practical test, the team decided to use just one particularly robust, compact and powerful motor type from Faulhaber with a suitable encoder and planetary gearbox. The motor used, from the 2342 ... CR series (Fig. 2), has a diameter of just 23 mm and a length of 42 mm and offers a continuous torque of up to 19 mNm as well as a high level of efficiency, meaning that the robot can dive autonomously for a long time on just one battery charge.
Engines working under high pressure
A normal motor would stop working far above the hadal zone - either because seawater ingress would destroy it from the inside or - even if it is sealed - the prevailing ambient pressure would crush it from the outside. Accordingly, there are two ways in which a DC-micromotor can fulfill its function under these conditions. One solution is to house the motor and other pressure-sensitive components in a pressure-resistant housing. The researchers at Hades-ERC were able to do this for many components with a pressure-resistant titanium cylinder. However, some components such as the motor and gearbox can only perform their work in contact with the environment being researched. This is why another solution is used here: it makes use of the fact that the force acting on the components is not determined by the total pressure per se, but by the pressure difference between the inside of the components and the external ambient pressure. The motor and gearbox are therefore located in a further cylinder filled with an inert liquid which, unlike salt water, does not restrict their function. This cylinder can adapt the internal pressure to the ambient pressure via a flexible membrane. The pressure equalization ensures that the high pressure prevails both inside and outside. This means that no force is exerted on the components.
With these highly reliable and pressure-resistant drives, the Hades ERC robot is ready to explore the ocean depths. The project is scheduled to run for five years and the first dives in three Pacific trenches - the Japan, Atacama and Kermandec trenches - will begin in fall 2018.
Authors:
Andreas Seegen is Head of Marketing at Faulhaber;
Marco Antoni is an employee of the Stutensee editorial office.
Mobile machines
Hydraulic cylinders become smart
Avoiding sudden machine breakdowns and optimizing maintenance routines - what operator of mobile machinery wouldn't want that? Vehicles can provide the necessary information automatically - for example with the help of position measurement in...
Mobile devices
Smart support
Mobile devices are inexpensive, constantly online and with their apps, up-to-date information is quickly available at all times. This also opens up potential in the industrial environment, but requires well thought-out integration.
