Humanoid robots in industry
Melanie Steinbeck,
Schaeffler cooperates with Humanoid
The German industrial group Schaeffler and the British technology company Humanoid have agreed a strategic partnership for this purpose. The aim is to equip humanoid robots with precise actuators and integrate them into industrial processes on a large scale.
Schaeffler will integrate humanoid robots from Humanoid into its global manufacturing network. © Schaeffler
For Schaeffler, traditionally known as a supplier for automotive and mechanical engineering, this is a step into a new business field. "As a motion technology company, we want to play a key role in the growing market for humanoid robotics. We are relying on our decades of manufacturing excellence and industrialization expertise. With Humanoid, we are gaining an attractive partner in Europe that will enable us to jointly drive innovation in the field of humanoid robotics," says Klaus Rosenfeld, CEO of Schaeffler AG.
Real application of humanoids in large numbers
For Humanoid founder Artem Sokolov, scale is crucial. The technology has proven itself over the years in demonstrations and proof-of-concepts, but only large-scale application in real production environments will really put the robots to the test:
(from left) Georg F. W. Schaeffler, family shareholder and Chairman of the Supervisory Board of Schaeffler AG, Artem Sokolov, CEO and founder of Humanoid and Klaus Rosenfeld, Chairman of the Board of Management of Schaeffler AG, sealed the technology partnership. © Schaeffler
"For years, humanoid robotics has taken place in labs, product demonstrations and proof-of-concepts, but real-world, large-scale application is when the technology is truly put to the test. At Humanoid, we believe that the future of humanoid robotics will not be defined by the most impressive demonstrations, but by the ability to scale up and deploy in real-world environments. This large-scale application is an important step towards that future. It allows us to validate humanoids in real-world conditions and pave a clear path to commercial use in the coming years. Together with Schaeffler, we are proving that humanoids can work reliably, safely and efficiently in industrial environments."
Humanoid robots:. It all depends on the actuators
Central to the partnership is the actuator technology - the joint movement of the robots. Schaeffler supplies shaft gear actuators, linear and rotary actuators that combine precision, resilience and efficiency. They are located in the shoulders, arms and upper bodies of the humanoids.
Schaeffler's shaft drive actuator combines precision and lightweight construction for use in modern humanoid robots. © Schaeffler
The design enables internal cabling, high freedom of play, low friction and is designed for series production. Andreas Schick, Board Member for Production, Supply Chain Management and Purchasing at Schaeffler, describes the ambition:
"Humanoid robots stand for movement and precision in perfection. With our comprehensive manufacturing excellence in high volumes and strong vertical integration, we offer innovative products of the highest quality. Thanks to the close integration of development and production, we realize tailor-made solutions that will take modern humanoid robots to a new level."
Economic and social context
The partnership shows that humanoid robotics is no longer a niche project. For industrial companies, it is all about efficiency, automation and scalability. At the same time, the industry is facing challenges: high production costs, complex logistics and the integration of robots into existing work processes. Humanoid robots could supplement work processes, not necessarily replace them - especially in repetitive or physically demanding tasks.
The investment in humanoid robots is also a signal to industry: companies like Schaeffler are focusing on technological leadership and want to be not just suppliers, but partners for the digital transformation. The ability to use robots on an industrial scale could become a competitive factor in the future.
