Linear axes
Quelle: Rollon | Inka Krischke,
Frame made of extruded anodized aluminium
The specially protected linear axes of the Plus System product family from Rollon act as the basis for multi-axis systems, Cartesian axis robots or the linear movement of SCARA robots. The system consists of the three product series 'ELM', 'Robot' and 'SC'.
© Rollon
All linear axles in the system have a self-supporting frame made of extruded anodized aluminium. They are driven by a steel-reinforced toothed belt. For applications in harsh environments or where there is frequent contact with water, all linear axes in the system are also available as corrosion-protected versions with durable stainless steel elements. The 'ELM' series offers four sizes from 50 to 110 mm profile width. The carriage is moved by linear guides or by an optional roller system. The linear axes of the 'Robot' series are suitable for applications with high load ratings where the carriage is subject to strong forces or for linear movements of complete SCARA robots to be used in production lines. The 'Robot' linear units are available in four sizes from 100 mm to 220 mm profile size. The linear axes of the "SC" series were specially designed for use as vertical axes in gantry construction or for applications in which the aluminum profile moves while the carriage remains stationary. They are available in three sizes with profile widths of 65 mm, 130 mm and 160 mm.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
