Kuka
For loads from 480 to 800 kg
The robots in Kuka's KR Fortec ultra family are designed for the heavy payload range from 480 to 800 kg.
© Kuka
The family consists of five robot variants - each of them suitable for a specific application. The 'KR 800', for example, is suitable for handling payloads of up to 800 kg. The two KR 480 variants have reach ranges of up to 3,700 mm. In addition, the maximum permissible mass moment of inertia of the KR 640 and KR 560 can be further increased with a high inertia variant for particularly large grippers. According to Kuka, the robots' double swing arm arrangement ensures high rigidity and accuracy with a reduced dead weight. The robot components are easily accessible and therefore easy to maintain and repair. Only three different maintenance measures are required: oil change, visual inspection and lubrication of the cable set and the bearings on the counterbalance.
Automatica 2022
Mechanics meets digitalization
The robotics industry meets at Automatica in Munich and showcases the latest trends and topics relating to the mechanical helpers. Included: megatrends such as digital transformation, artificial intelligence, sustainable production and man and...
Kuka
Cobot assistant for SMEs
A user-friendly cobot application for small and medium-sized companies that can be used without programming - a team of researchers from Belgium received the Kuka Innovation Award 2024 for this concept.
