ETH Zurich
Artificial muscles for robotic leg
Researchers at ETH Zurich and the Max Planck Institute for Intelligent Systems have developed a robotic leg with artificial electro-hydraulic muscles that automatically adapts to uneven terrain.
The robot leg jumps over different terrain
© Thomas Buchner / ETH Zurich and Toshihiko Fukushima / Max Planck Institute for Intelligent Systems
The robotic leg can perform high jumps and fast movements as well as recognize and react to obstacles without complex sensors. It was developed by researchers from ETH Zurich and the Max Planck Institute for Intelligent Systems (MPI-IS) as part of the research partnership known as the Max Planck ETH Center for Learning Systems, or CLS for short. The CLS team was led by Robert Katzschmann from the Soft Robotics Lab at ETH Zurich and Christoph Keplinger from the MPI-IS
Conventional robotic legs are driven by an electromagnetic rotary motor (left), while the researchers use electrohydraulic actuators - artificial muscles - in the musculoskeletal system (right).
© Thomas Buchner / ETH Zurich and Toshihiko Fukushima / MPI-IS
As in humans and animals, an extensor and a flexor muscle in the robot leg ensure that movements are possible in both directions. These electro-hydraulic actuators, which the researchers call 'Hasels', are attached to the skeleton via tendons. The actuators are plastic bags filled with oil. Around half of the bag is coated on both sides with a black electrode, i.e. a conductive material. As soon as voltage is applied to the electrodes, they attract each other due to static electricity. If the voltage is increased, the electrodes pull closer together and push the oil in the bag to one side, making the bag shorter overall. Pairs of these actuators, which are attached to a skeleton, lead to the same paired muscle movements as in living beings: When one muscle shortens, its counterpart lengthens. The researchers use a computer code that communicates with high-voltage amplifiers to control which actuators should contract and which should lengthen.
More efficient than electric motors
If robot legs have to hold a certain position for a long time, a lot of current flows through the driving DC motor (left). Over time, energy is lost in the form of heat. In contrast, the artificial muscles remain cold (right). The artificial muscles work on the principle of electrostatics and are efficient because they have no current flow under constant load.
The researchers compared the energy efficiency of their robotic leg with that of a conventional robotic leg driven by an electric motor. Among other things, they investigated how much energy is unnecessarily converted into heat. "On the infrared image, you can quickly see that the motorized leg consumes much more energy if it has to be held in a bent position, for example," explains doctoral student Thomas Buchner. In contrast, the temperature in the electrohydraulically driven leg remains the same, which is due to the fact that the artificial muscle is electrostatic. "Electric motors require heat regulation, which means that additional cooling units or fans are needed to dissipate the heat into the air. Our system does not require such components," adds doctoral student Toshihiko Fukushima.
Agile movement over uneven terrain
The robot leg's jumping ability is based on its ability to lift its own weight explosively. The researchers were also able to show that the robot leg has a high degree of adaptability, which is particularly important for soft robotics. Only if the musculoskeletal system has sufficient elasticity can it adapt agilely to the respective terrain
While a sensor has to constantly tell the electric motor what angle the robot leg is at, the artificial muscle adapts adaptively by interacting with the environment. It constantly receives the same two input signals as a drive: one for flexion and one for extension of the joint. Fukushima explains: "The ability to adapt to the terrain is a key aspect. When a person jumps into the air and lands, they don't have to think about whether they should bend their knees at a 90-degree or 70-degree angle." The same principle applies to the musculoskeletal robot leg: if the environment is soft, the robot leg reaches a different joint angle than on a hard surface.
Technology opens up new possibilities
The research field of electrohydraulic actuators is still young and has only existed for around six years. Katzschmann says that electrohydraulic actuators will probably not be used in heavy machinery on construction sites, but that they offer specific advantages over standard electric motors, especially in applications with robotic hands, where the movement has to be very individual and adaptive, depending on whether it is a ball, an egg or a tomato, for example. However, he qualifies: "The current system is still limited compared to walking robots with electric motors. At the moment, the leg is attached to a pole, hops in circles and cannot yet move freely." Future work should overcome these limitations so that real walking robots with artificial muscles can be developed. Katzschmann continues: "If we combine the technology of the robotic leg into a four-legged robot or a humanoid robot with two legs, we will one day be able to use it as a rescue robot as soon as it is battery-powered."
