Mobile industrial robots
Quelle: Omron Electronics | Inka Krischke,
Alternative to driverless transport systems
Omron introduces the LD platform, a range of mobile industrial robots for material handling in large-scale facilities. The robots are particularly suitable for transporting goods in warehouses, distribution centers and production facilities.
© Omron Electronics
Depending on the model, their payload capacity is up to 130 kg. In contrast to conventional automated guided vehicles (AGVs), the mobile robots navigate according to the spatial characteristics of the system and therefore require neither expensive and time-consuming conversions nor floor magnets, guide belts or laser signals. This enables a flexible system layout, as the transfer points for the mobile robots can be easily changed. In combination with conventional automation systems, the robots can be used like conveyor belts, whereby the products can be easily tracked. The robots are equipped with a robust navigation system that enables them to navigate independently under dynamic conditions - even in the midst of moving people, pallets, trolleys and forklift trucks. Thanks to integrated AI, they avoid obstacles and choose the optimal path for the task at hand. The intelligent motion control also ensures that they can work safely with people.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
