Fraunhofer IPA
'Milestones in robotics' exhibition extended
After two billion grips, it can retire - the 'IRB 340 Flexpicker'. The delta robot for handling tasks from ABB has been enriching the Fraunhofer IPA's 'Milestones in Robotics' exhibition since October 1, 2021.
Delta robot 'IRB 340 Flexpicker' from ABB in use at Unilever: A team of four Delta robots was able to pick up 150 salami sausages in just one minute.
© Robomotion
The delta robot was used at Jacklinks (formerly Unilever) for around 15 years: in a team with three other robots, the ABB robot gripped more than 500 million Bifi sausages from a feed belt under camera control and placed them in the prepared thermoforming film for sealing. Together, the four robots have handled over two billion sausages.
In its in-house exhibition 'Milestones in Robotics', Fraunhofer IPA honors research achievements from almost 50 years of robotics at the institute. Extensive scientific and technical groundwork for the new exhibit was carried out at Fraunhofer IPA from the mid-1990s with developments on the topic of 'robots on conveyor belts' and subsequently the founding of the company Robomotion by former Fraunhofer employees in 2003.
Demand for the salami snacks was very high in the 2000s. The manufacturer, then still called Unilever, was faced with the challenge of having to sort the sausages produced as quickly as possible - a laborious task by hand. Robomotion was able to automate this task based on the IPA developments. But gripping sausages is a challenge for a robot. It must be able to recognize their shape and size and then pick them up easily - even though their surface is very difficult to handle. In addition, the food industry has extremely stringent hygiene requirements. Nevertheless, the robot on show at the exhibition managed the required cycle times of 150 sausages per minute without any problems and also improved process reliability.
As part of the Bifi project, developments were also carried out with the Fraunhofer IPA on the use of 3D-printed grippers on robots. As a result, Unilever began using the weight-optimized triple grippers in production in 2009.
ABB
Change at the top of ABB Robotics in Germany
ABB has appointed Jörg Rommelfanger as the new Head of the Robotics division in Germany with effect from January 1, 2022. As Head of the Automotive business line, the 48-year-old will also be responsible for the Robotics division's automotive and...
Fraunhofer IPA
Improved safety for service robots
In the S³ research project, researchers at Fraunhofer IPA and their project partners have developed safety technologies and recognition algorithms for service robots. They were tested on the Care-O-bot 4 service robot in a nursing home application.
ABB
AI for autonomous mobile robots
ABB is entering into a strategic partnership with Sevensense. The start-up will expand ABB's new portfolio of autonomous mobile robots (AMR) with artificial intelligence and 3D mapping technology.
Special
Robotics&AUTOMATION 3/2021
Is an industrial robot without a cage really safe? What needs to be considered in the planning phase of human-robot collaborations? And what does a gecko have to do with robotics? The latest e-paper from Robotics&AUTOMATION provides the answers.
ABB at Nestle
Without a cage, but still safe!
Particularly high safety requirements apply at the interfaces between humans and robots. However, this is precisely where enormous efficiency potential can be exploited, as the example of the modernization of a 'Kitkat' factory shows.
