Rotor blade monitoring
Quelle: Weidmüller Interface | Inka Krischke,
Effectively prevent system downtime
Bladecontrol from Weidmüller is a system for monitoring the rotor blades of wind turbines, whose sensor technology detects damage or icing at the initial stage.
© Weidmüller Interface
This allows measures to be initiated at an early stage to prevent a system standstill. In the event of serious damage, the system sends a signal to the turbine control system, which can then stop the turbine immediately and prevent blade breakage. The system consists of sensors on the rotor blades, a hub computer (HMU), optional data transmission via WLAN (APNAC), an evaluation and communication computer (ECU), a database computer (DBS) and a web-based graphical user interface (WebVIS).
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
