Expo 2017
The body as a power source
Cell phone empty, power bank empty, second power bank also empty and no sun. When all portable power sources fail, there is only one thing left to rely on: your own body. Researchers at the Karlsruhe Institute of Technology are working on using it to generate electricity.
With systems that convert body energy into electricity, such as this foot prosthesis, KIT researchers want to operate portable electrical devices such as smartphones or pacemakers.
© KIT - Andreas Kell
Smartphones, MP3 players, heart rate monitors: a growing number of electronic companions are making our everyday lives easier. But as useful as these smart helpers may be, their constant hunger for power is a problem. One possible solution is to power them using the body's own kinetic energy. Researchers at the Karlsruhe Institute of Technology (KIT) are working on this.
Mini power station in the shoe
An important criterion is that the generation of electricity does not require any additional effort from the user. Medical scientist Christian Pylatiuk from the Institute for Applied Informatics (IAI) and his team have developed two systems based on this requirement. One design for the feet uses the body's weight when walking. A small cushion filled with fluid is placed under the heel and ball of the foot. When stepping and rolling, oil is pumped back and forth through a hose connection between them and drives a piston, which in turn drives a generator. The mini-electricity unit is currently installed in a prosthetic foot fitted with sensors, which actively supports the wearer's movements.
Moving with the times
Another generator can be worn on the arm like a watch. The difficulty here: In order to operate a generator, the very unsteady arm movements must be converted into a smooth movement. Pylatiuk has used a tried and tested technique for this. In contrast to the movement of an automatic watch, where the energy is stored by means of an oscillating weight tensioned by a spring, an induction motor is active here, in which an eccentric moves a magnet back and forth in a coil. However, the maximum output of 2.2 milliwatts is not yet sufficient to operate a hearing aid or charge a smartphone, for example. However, the KIT researchers expect improved results by the end of the year.
Expo 2017
Both devices are currently on display in the "Kinetic Lab" of the Museum for Energy of the Future at the Expo 2017 world exhibition, which is taking place in the Kazakh capital Astana until September 10. In addition to KIT, companies such as Samsung, Siemens and BMW are also represented there. This year's world exhibition is dedicated entirely to the topic of energy of the future. The topic area covers renewable energies, global warming and global energy supply.
Most read
The top articles in July 2024
Innovative spirit and entrepreneurial thinking characterize the most-read articles from July. Find out more about competitive advantages through AI, click through award-winning developments and read more about model-based design and quantum sensor...
The EDAI project
In the EDAI project, researchers at the Karlsruhe Institute of Technology (KIT) are combining the design of AI algorithms and AI chips. EDAI is based on open source software to facilitate access to AI-based solutions, particularly for small and...
FZI
Sustainability is digital
The motto of Hannover Messe 2024 is Energizing a Sustainable Industry. With numerous research projects, the FZI Research Center for Information Technology presents the possibilities of digitalization on the way to a sustainable and more...
Festo
Intelligent robots thanks to AI
Festo hosted the conclusion of the Flairop research project, which worked on making order picking robots more intelligent using distributed AI methods. The project was funded by the German Federal Ministry for Economic Affairs and Climate Protection.
