Give
Sterilizable cover optional
The Really Cool from Gebe is a silicone keyboard that has now been equipped with an additional sterilizable silicone cover. Users in the laboratory, for example, benefit from the extra protection of a smooth surface without loopholes.
© Give
The cover material of the silicone keyboard from Gebe is made of latex-free silicone, which is suitable for disinfection or cleaning in an autoclave or thermodisinfector. The cover is designed for long-term use and is supplied as an optional accessory.
The DIN IP68-protected silicone keyboard is equipped with a USB port and is also available with a built-in touchpad. The sterile silicone keyboard gives the user the feeling of a modern laptop keyboard, while at the same time offering a high degree of protection and withstanding regular disinfection. The so-called 'TruLock' mechanism allows it to be locked during the cleaning process to prevent unnecessary entries or commands. The device is certified according to DIN EN60601 and supports all common operating systems.
Eplan
Switch cabinets in virtual space
With the AR-supported application Eplan eView Free AR, Eplan brings the digital twin to wherever users are. Designers share their 3D designs of the enclosure layout from 'Eplan Pro Panel' with colleagues and business partners via the cloud.
GeBe
Improved insulation for touchpads
The TVG-Touch built-in module from tastaturen.com consists of a capacitive touchpad integrated into a stainless steel front panel, which has been provided with an improved insulating protective layer.
GeBe
