Rafi
Andrea Gillhuber | Inka Krischke,
Placed directly on the touchscreen surface
Rafi equips the 'Glasscape' touchscreens with haptic operating solutions: The Flexscape One and Flexscape Wheel control elements are placed directly on the touchscreen surface and enable safe function control without visual contact.
The 'Flexscape One' pushbutton is used for haptic switching of functions on the touchscreen.
© Rafi
The 'Flexscape One' push button is used for haptic switching of functions on the touchscreen, is activated by touch and requires a pressure point to be overcome to switch the selected touch function. A perceptible and acoustic feedback confirms its activation. Flexscape Wheel' can be used to select functions or set parameters depending on the context. The concise contours of the circular finger guide provide tactile orientation for safe blind operation.
Thanks to their compatible geometries, the Rafi control elements can also be combined to form a single element with all functions. This further increases operating safety, for example by only activating or accepting functions or values selected via the wheel after the button has been pressed. As the actuators are fixed in place without perforations or holes, the touch surface remains closed and its stability and impermeability are fully maintained.
Rafi
Signaling of three operating states
Rafi is expanding its 'Rafix 30 FS+' range of control and signaling devices to include an LED signaling light with a stainless steel front ring that is just 3.45 mm flat and is suitable for signaling three signaling states thanks to its integrated...
Eaton
Operation even with gloves
Eaton is adding a fully graphic touch panel from the XV102 series to the 'easyE4' product family. The 3.5-inch touch panel with color display was developed for the visualization and operation of applications based on the 'easyE4' control relay.
