tci
Touch panels can be operated intuitively
With the E07A and E10A, tci presents two touch panels for industrial applications, for example in the areas of production, logistics and energy management. Android is used as the operating system.
The HTML5 AutomationBrowser is compatible with all common web applications and can therefore be used universally. The widescreen display with capacitive multi-touch (PCT) can be operated intuitively, just as users are used to from a smartphone or tablet. The panels' TFT color display offers a native resolution of 1024 x 600 pixels.
According to tci, the slimline web panels are equipped with an easy-to-clean continuous real glass front with IP54 protection and a lightweight, industrial-grade plastic housing. They can be mounted in a control panel, in a switch panel or via VESA. The panels do not have any rotating parts or fans. The 10-inch version is also available as a PLC operating panel (E10A-XS) for common control systems.
