TL Electronic
Magnesium alloy housing
The M133K is the next generation of the 13.3-inch tablet from TL Electronic and comes with the 7th generation Core i5.
In many industrial, mobile applications, a tablet has to withstand extremely demanding conditions. The M133K from TL Electronic is therefore manufactured with a housing made of a resistant magnesium alloy, rubberized all around and IP65-protected. The tablet withstands shocks, vibrations and drops in accordance with MIL-STD-810G. The 10-point multi-touch screen supports hand/rain mode, touch pen and glove operation, depending on the intended use. Thanks to its design with a wide viewing angle, the display is also easy to read outdoors.
The 10,280 mAh Li-polymer battery provides up to 11 hours of battery life and can optionally be replaced during operation. A wide range of connection possibilities and options for data acquisition, communication, docking, mounting, power supply, peripherals and transportation are available for (long-term) use.
