Panel PCs
Landscape or portrait format
The UTC-320E all-in-one computer from Advantech is available from gbm. The touch panel PC is equipped with a flat 21.5-inch widescreen display and can be operated either via a projected capacitive or a resistive touchscreen
It can be used in both landscape and portrait format. Thanks to the Intel Haswell i5-4300U processor and the expandability of the RAM to a maximum of 8 GB, the computer offers sufficient resources for computing-intensive applications. Six USB and two serial ports are available. The Panel PC can be integrated into existing network structures via its two GigaBit Ethernet ports; there is a WLAN module for wireless integration into networks. The Panel PC can be flexibly expanded with various peripheral modules using existing cut-outs. For example, barcode, RFID or magnetic card readers and a 5M camera can be attached. Standard VESA drill holes enable mounting on walls or support arm systems using a corresponding bracket. Thanks to its removable frame and installation depth of just 43.5 mm, the Panel PC can also be installed in a control cabinet.
