SR System Electronics
In the switch cabinet or as a console installation
The R-FLAT 19/FHD(-M) from SR System-Elektronik offers an alternative for 19-inch industrial monitors in the control cabinet or as a console installation.
© SR System Electronics
As the previous 19-inch monitors in 5:4 format offer the maximum resolution of 1280 x 1024, the 'SR-Line' series can also offer the full widescreen resolution of 1920 x 1080 as FHD (Full HD). When selecting the 19-inch TFT (18.5 inches in 16:9 format), care was taken to ensure that the mechanics remain compatible with previous 5:4 solutions. This means that the monitors are 1:1 interchangeable with previous applications.
An optional HDMI or display port is available for newer graphics applications. Key features of the monitor are a wide viewing angle of 178° on all sides, a contrast of 1000:1 and a maximum luminance of 350 cd/m². The LCD color screen with protective glass (IP65 on the front) is compatible with VGA, SVGA, XGA, SXGA and WUXGA (FHD). The on-screen display (OSD) enables the configuration of contrast, brightness, color balance, image geometry and other parameters.
parameters.
Eaton
Operation even with gloves
Eaton is adding a fully graphic touch panel from the XV102 series to the 'easyE4' product family. The 3.5-inch touch panel with color display was developed for the visualization and operation of applications based on the 'easyE4' control relay.
