Switches
Quelle: LNT Automation | Lukas Dehling,
For mounting on smooth surfaces
With the ITO-Key from the glass-to-touch series, LNT Automation has developed a pushbutton that can be mounted on smooth surfaces using an adhesive layer and is practically wear-free thanks to its capacitive technology.
© LNT Automation
The button is mounted using an adhesive film that ensures a secure hold on smooth surfaces. The key can be freely positioned independently of the display and can be attached to glass or acrylic glass up to 6 mm or 3 mm thick. If the surfaces are dry and free of dirt, dust, oil, grease and other contaminants, optimum bond strength is guaranteed, according to the manufacturer. The durability of the adhesive can be increased by pretreating the surface before installation. As the capacitive button is usually installed behind a closed surface and no breakthrough is necessary, cleaning is very easy, making the ITO-Key particularly suitable for use in areas with a high degree of contamination or strict hygiene regulations. Customers can configure the functionality of the button themselves. Using software developed specifically for the ITO-Key and a USB cable, customers can set various parameters themselves.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
E-T-A
Sensory in view
Intelligent power distribution systems are valuable helpers when it comes to digitalization in the IT rack. Monitoring the IT racks using sensors is a particularly effective measure for increasing system availability.
Ateg
Keyboards with glass surface
Ateg offers capacitive PC keyboards with a glass surface from the French manufacturer Tactys. The glass of the user interface is made of 3 mm thick, hardened white glass, which is robust against mechanical influences.
