Rose System Technology
Complete modular HMI system
Rose has designed the 'S-Line Gen. 5' panel PCs as a complete HMI system that is suitable for operation as well as for programming, visualization, long-term archiving and simulation of processes in all areas of automation.
The 'S-Line Gen. 5' panel PCs from Rose Systemtechnik
© Rose System Technology
The operating units can be individually assembled from various components: Accessories include command and signaling devices from different manufacturers such as RFID reader modules, WLAN antennas, touch pens and keyboards. There is a choice of four performance classes (Celereon/i3/i5/i7 10thGen) and three screen diagonals (18.5/21.5/23.8 inches). The Panel PCs from Rose Systemtechnik are available with different fronts - for example, completely made of glass or as a partial front made of glass and aluminum. In addition, the manufacturer adapts the Panel PCs to customer requirements in terms of color, both the housing frame and the lower partial front of the Panel PCs as well as the separator between the display and the lower partial front. The devices are available both as Panel PCs and in a monitor version.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
