HMI solutions
Quelle: T&G Automation | Lukas Dehling,
CE and cULus approved
The Esmart series from Exor features widescreen displays with LED backlighting and is available from T&G Automation in 4.3-inch, 7-inch and 10.1-inch sizes.
© T&G Automation
The CE and cULus approval of the operating device and the industrial quality of all components guarantee a high level of reliability. The devices are equipped with Ethernet, USB and serial interfaces. They are programmed using the intuitive JMobile software, which has an extensive function library - consisting of functions such as dynamic objects, data acquisition, alarm management, multilingualism, recipe management, tag editor, database, user management and scripting.
Exor
HMIs in the IoT age
Thanks to IoT and Industry 4.0, "things" are becoming connected - including HMIs. Exor is responding to this trend with the new X platform - with Node Red software and TSN standard.
HMI devices
Node programming thanks to Node-RED
The JSmart IoT Web-Based HMI device from Exor with PCAP multi-touch offers protection class IP69K. With the patented mounting via a standard 22 mm hole, the 12.5 mm thick display can be easily mounted anywhere on a machine or system.
