Exor
Control panel also for IIoT edge applications
With the HMIs of the 'JSmart' series, which are available in two variants, Exor has a range of operating panels in its program that are suitable for factory, ship and building automation.
© Exor Germany
The 'JSmart700M' products are robust operating panels with a support arm system. Their multi-touch display is therefore close to the operator at all times and ensures that communication between man and machine is guaranteed. For applications in critical areas where a powerful HTML5 web browser is required, there is the 'JSmart700M Browser Panel' with a large display with capacitive multi-touch touchscreen and robust glass front. Both displays are available as HTML5 web panels as well as with the 'JMobile' software. According to the provider Exor, the easy-to-learn software covers the areas of connectivity, device management, process management and data visualization. The panels can also be used as a controller with Codesys and IoT Gateway for the Corvina IoT platform and secure VPN remote maintenance access.
In focus: HMI
The e-paper of issue 06/23
How can digitalization and artificial intelligence help to make production processes sustainable? How can cobots and automated guided vehicles bring variety to everyday working life and how can they support people? Starting points in this issue.
Exor
HMIs in the IoT age
Thanks to IoT and Industry 4.0, "things" are becoming connected - including HMIs. Exor is responding to this trend with the new X platform - with Node Red software and TSN standard.
HMI devices
Node programming thanks to Node-RED
The JSmart IoT Web-Based HMI device from Exor with PCAP multi-touch offers protection class IP69K. With the patented mounting via a standard 22 mm hole, the 12.5 mm thick display can be easily mounted anywhere on a machine or system.
