Monitors
Can also be used outdoors
Comp-Mall is expanding the DM-F monitor series with the two widescreen formats 15" and 19". DM-FW15A and DM-FW19A are suitable for use in industrial automation as machine displays, HMIs, in control rooms or as kiosk terminals.
The OSD keypad is located on the rear, and the IEI Smart OSD function enables remote monitor settings in the Windows environment. The anti-glare display reduces reflections and eliminates light interference. Thanks to the IP65-protected front and a wide operating temperature range of -20 to +60 °C, the display can also be used outdoors. The maximum resolution is 1366 x 768 pixels (16:9), the brightness is 400 cd/m² and the viewing angle is 170° horizontal and 160° vertical. In terms of interfaces, the monitors offer VGA, HDMI and DisplayPort; the 19-inch model also has a DVI connection. One USB 2.0 and one RS232 are provided for the touchscreen connection. The power supply is between 9 and 36 V(DC). Thanks to various mounting options, the monitors can be mounted in control cabinets, on control panels, in machine housings or using VESA 100.
