Guidance systems
Quelle: Yokogawa Deutschland | Lukas Dehling,
13,000 data points in one diagram
Yokogawa presents the new version R6.02 of the integrated process and production control system Centum VP R6.02.
© Yokogawa Germany
According to the manufacturer, this has a more powerful real-time trend function for visualizing the operating status of the system and an improved alarm function. In addition, Prosafe-RS R4.01 can be seamlessly integrated. The company has doubled the number of trend lines within a trend window to 16. The maximum number of data points that can be displayed on a graph has also been doubled and is now approximately 13,000. Additional trend lines can be dragged and dropped from any level of the operator station (graph, alarm list) into any trend window. With these new functions, operators should benefit from faster and more convenient access to system-specific data. A new function is also designed to display real-time trend data and archive data in the same window, allowing operators to track changes that have occurred over a longer period of time without losing sight of current values.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
