Panel PCs
Quelle: ICP Deutschland | Inka Krischke,
1280 x 800 pixel resolution
HMI panels and POS/POI terminals are generally used for clearly defined applications that do not place high performance demands on the system; the focus is on immediate readiness for use and a compact and attractive design.
© ICP Germany
ICP Germany combines these features in the 10.1 inch RISC-based Ready-to-Use Panel PC IOVU-10F with a resolution of 1280 x 800 pixels. Pre-installed on the 4 Gbyte eMMC Nand Flash, the Android 4.2.2 operating system is based on a Freescale i.MX6 Cortex - A9 Quad Core 1.0 GHz RISC processor with 1 Gbyte DDR3 SDRAM memory. The Panel PC has a scratch-resistant capacitive touchscreen (IP54), which is embedded in a slim housing (293 mm × 210 mm × 45 mm). The metal rear of the Panel PC has one GbE, two USB 2.0, one RS232/422/485 and one RS232 vertical downwards interface. A WiFi and Bluetooth controller and an SD slot with a maximum storage capacity of 32 GB are also integrated. Other features include flexible mounting options (wall, panel, stand and arm mounting), an input voltage range of 9 to 30 V(DC) and an operating temperature of 0 to +40 °C.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
